587,065 active members*
3,834 visitors online*
IndustryArena Forum > CAM Software > Mastercam > revive corrupted file
    Nov 2010
    I was working on Mastercam, an error message popped-up:
    "memory error #322..., mastercam need to be closed..."
    After close it, rerun mastercam but the file I was working on can not be opened due to the message "invalid corrupted file..."
    How can I fix this file? I put a lot of work on it.
    Thank you
    Dec 2008
    3122
    That file may not be resurected and have to be completely ignored
    If you have "Autosave" running, or you have "Backup" going, this may be the only avenue, you would only lose a small amout of work up to your last save or autosave time schedule you have set.
    Nov 2010
    Corrupted file
    Thank you superman.
    Unfortunately, the autosave was turned on but it inadvertently saved the bad file at the moment mastercam went bad and forced the close.
    Thank you
    Dec 2008
    3122
    What about the "Backup files" ?
    this is seperate and additional to "Autosave"
    try looking in your "BACKUP" folder----you may have had it ON
    sort by time, and it should be at the latest file
    If Backup is ON and you save a file, then the backup is incremently shuffled down by one to the maximum number you have set. At leest you would be able to go to file that was saved
  1. Partner Lathe "Parameter File Corrupted"
    By Joe Miranda in forum Milltronics
    Last Post: 09-03-2011, 03:25 AM
  2. Corrupted Tool Library in V23
    By Perfect Circle in forum BobCad-Cam
    Last Post: 01-03-2011, 04:17 PM
  3. Corrupted Data
    By dandonegan in forum Centroid CNC Control Products
    Last Post: 11-16-2009, 07:09 PM
  4. X2 died. Must revive!
    By voltsandbolts in forum Benchtop Machines
    Last Post: 05-07-2008, 07:30 PM
  5. BCC v22 Speed/Feeds corrupted if file saved without post
    By brooklynmetal in forum BobCad-Cam
    Last Post: 03-25-2008, 02:33 PM
