Hi all. I have just released an updated version of NCCL that includes some bug fixing and a new small application entirely written in this language. It does have a user interface written in AutoiT that helps creating the script that is then executed.
The application does two things :
1) Convert one or more files from stanrdard ISO code to DXF
2) Create a report with some basic information about the processed file including a forecast about the time it will (should) take to machine the workpiece.
If someone want to try it and compare with the true machining times, I woukd like to know how accurate is the calculation. It only works with 3 Axis cnc code. 5 Axis is not supported (may be in the future..)
If you want to give it a try just go here : Main Page
Many thanks
Sandro
