586,077 active members*
4,039 visitors online*
Results 1 to 9 of 9
    May 2009
    393
    SPACE buffering in DNC Unit
    I was wandering that how DNC Unit Interprets a NC program with SPACE characters.
    For Example -
    N1 G90 G54 G90 G17
    N2 M03 S500
    N3 G00 X40.0 Y40.0 Z20.0
    N4 G01 Z-2.0 F500
    N5X52.075Y-103.576
    N6X50.063Y-103.019
    N7X49.843Y-102.854
    N8X47.612Y-101.915
    N9X45.380 Y-100.739
    N10X44.404Y-100.050
    N11G0Z39.014
    N12 G1X44.019Y-115.923F9900
    N13G0Z37.014
    N14G1Z35.717F500
    N15X44.513Y-116.306F3000
    N16X48.296Y-114.177
    N17 X49.843Y-113.585
    N18X54.306Y-112.398
    N19X58.770 Y-112.104
    N20X63.233Y-112.579
    N21X65.464Y-113.216
    N22X67.696 Y-113.958
    N23X69.927Y-114.982
    N24 M05
    N25 M30
    IS IT POSSIBLE FOR A DNC TO INTERPRET THE Above mentioned program correctly ?
    Ashish
    2932
    What is a DNC unit?
    If you mean a CNC control I believe a Fanuc will "interpret" the program correctly.
    May 2009
    393
    Thanks for your reply.
    Older systems (Like 6M Control) don't have sufficient memory to interpret BIGGER SIZED Programs. It may be a NC Program created from a CAM software.
    So, DNC Unit works as a OBJECT to read the Huge NC programs from personal computer, buffer it properly & then pass it on to the MACHINE CONTROL.
    Machine control executes the program accordingly.
    I hope that I was not too confusing.
    Ashish
    2932
    I know what DNC is, I've just never heard it referred to as a "DNC unit".
    May 2009
    393
    Any IDEAS on the problem mentioned by Me.
    Ash
    2932
    Quote Originally Posted by Ashish B View Post
    Ash
    What PROBLEM?
    May 2009
    393
    I had the doubt that will the DNC Unit buffer properly a NC Program which has irregular spaces between the codes.
    Ashish
    2932
    Ashish
    According to the Fanuc 0M-C manual, spaces are ignored unless they are within a comment:
    "If it is used in a statement other than a comment, the character will not be registered in memory. If used in a comment, it will be registered in memory."
    May 2009
    393
    Thanks Dcoupar,
    For that valueable information & insight on buffering pattern of a NC program.
    Ashihs
  1. suppressing buffering
    By sinha_nsit in forum Fanuc
    Last Post: 10-17-2018, 02:53 AM
  2. FANUC 15-MA Battery unit & I/O unit etc
    By gbowne1 in forum Fanuc
    Last Post: 05-05-2010, 02:47 AM
  3. Space in Frederick MD
    By dgapilot in forum Mentors & Apprentice Locator
    Last Post: 02-26-2008, 01:58 AM
  4. Anyone else have space issues?
    By cxixer in forum DIY CNC Router Table Machines
    Last Post: 10-15-2007, 04:37 AM
  5. Paper space Model space ??
    By cncadmin in forum Autodesk
    Last Post: 05-29-2003, 12:07 PM
