586,103 active members*
3,404 visitors online*
    Jan 2011
    431 z axis servo excess error
    I have a clausing stingray cv1000 with a fanuc o-md contorller on it. The problem I am having is with the z axis. it will go down but not always up. Sometimes when I go up it will skip and alarm out. The alarm I get is 431-servo alarm z axis excess error. I was told it might be the motor so I swapped it with one of onother cv 1000, same motor. I got the same results. It does not do this all the time, sometimes it will go all day without acting up, other days it will act up all day or intermitent. Any help would be great.
    Chris
    Jan 2011
    It also only seems to do it after it sits for a couple of days.
    Apr 2013
    12
    check the current
    Feb 2011
    640
    assuming its a vertical spindle mill/ gravity axis? if so is the brake releasing (if it has one in the servo).
    is counterbalance by weights or gas springs? if gas springs, accuumulator might need recharged.
    otherwise, check the way lube is good, maybe get a mechanics stethoscope and listen to the ballnut and thrust bearings for rumble in one direction... a torque wrench on the screw can tell you a lot too- just be sure everythings blocked in case counterbalance is not working before pulling motor/brake
    a common issue on our vertical screws is the lower screw bearings get crap pushed thru the seals and lock up- hate to admit, but most of our machines have had the lower bearings left out for years...not right for sure, but dont seem to hurt the uppers(we run mostly aluminum) and saves a lot of downtime...some screws are loaded from both ends so leaving one end free isnt possible without reorienting the upper bearing thrust directions...most of ours just have a radial lower bearing to prevent shaft whip, but Ive never seen a issue without it...
  1. Mazatrol T1 Excess Z error and NHead Lube
    By c5chris99 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-03-2011, 09:56 AM
  2. Replies: 6
    Last Post: 01-14-2011, 05:16 AM
  3. Alarm 410 V axis Excess Error, FIX?
    By D_Flannery in forum Fanuc
    Last Post: 01-14-2011, 05:13 AM
  4. Fanuc 21i 411 excess error
    By ceilingwalker in forum Servo Drives
    Last Post: 03-18-2010, 06:55 PM
  5. partner 1 Z axis excess error problem
    By blowncoupe in forum Milltronics
    Last Post: 10-18-2008, 03:20 AM
