Originally Posted by
spainguy
I've being playing with my new Sherline mill for a few months, nothing serious, just getting the hang of basics, aluminium only work.
Today I tried to remove the standard end mill holder, which has been fitted for a week or so and it was seized solid to the headstock spindle. It was fitted finger tight only. It's quite humid in this part of Spain at the moment.
I've soaked it with WD40, no luck.
Before I take the motor off and remove milling assembly and put the end mill in a vice is there anything I should not do?
Should I use my butane torch to heat up the end mill?
Martin
