586,510 active members*
3,137 visitors online*
IndustryArena Forum > MetalWorking Machines > Mikinimech > How are you clamping your vise down?
    Feb 2009
    2143
    I bought 2 of the 6" vises from Mikini. I was expecting them to be the Kurt vise style with tab "ears" that bolt directly to the table using T-Nuts (as is shown on the Mikini site). Phil said they switched to this new type in 2010, and they don't have T-bolt tabs on them - in order to mount them to the table I have to clamp them with step clamps, which ends up being a pretty bulky setup...
    What are the rest of you doing?
    I don't have a pic of mine to post right now, but was thinking maybe drilling through it off-center to bolt it down directly.
    Looking for something that is less bulky than what I have on the table now...
    can you bolt them to a sub plate
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Feb 2009
    2143
    I could tap the vise and bolt a sub-plate to that, then bolt the plate to the table... That's probably a better idea the drilling out a hole through the vise... MIC6 sub-plates should work, and I have some stock... Good idea if I don't fine a more "friendly" clamping solution... The vise does have a keyway slot that would be nice to use if I can, but I guess I could also slot the sub-plate and use a key on both sides (one for the vise and one for the table)...
    Nov 2010
    Aloha Mike,
    could you post a pic of the new style vise? I originally ordered 2 as well, but ran into a deal on a pair of GMT vises. I thought, as you did, that the Mikini vises had tabs. The GMT premiums have bolt slots as well as a clamping lip, and the GMT standard have the tabs. Could you mill bolt slots into the base of yours?
  1. CT129N Clamping kit ???
    By mindstorm88 in forum Benchtop Machines
    Last Post: 09-28-2010, 01:32 AM
  2. Clamping with a rod
    By thatstephen in forum Uncategorised MetalWorking Machines
    Last Post: 05-08-2009, 06:00 AM
  3. Okuma O.D. to I.D Clamping
    By pyropainter in forum Okuma
    Last Post: 07-04-2008, 06:28 PM
  4. Clamping Kits/New Vise?...?
    By CROSSHATCH in forum Benchtop Machines
    Last Post: 11-05-2007, 05:47 PM
  5. Home Made Vise Stop - For 6" Kurt Vise
    By widgitmaster in forum Bridgeport / Hardinge Mills
    Last Post: 12-15-2006, 03:49 PM
