586,104 active members*
3,250 visitors online*
Results 1 to 11 of 11
    Jun 2005
    91
    Bridgeport Series I Motor Wiring
    I have an older Bridgeport Series I mill with a 1.5HP US Motors motor on it. The wires were cut at the electrical box on the motor. How do I know which wires are which? I see there are two sets of wires bound together. One set has 4 wires while the other set has 5. Any help would be appreciated as I would love to get my mill going.
    Nov 2004
    3028
    Do I see little bands wrapped around each wire about a quarter inch wide? Those may be the missing wire numbers. Take a look.
    George
    Jun 2005
    91
    I wish
    Unfortunately, the labels say nothing. They are actually small copper clips that have been bent around the wire.
    Jul 2010
    369
    There should be three wires from the motor connected together, and then each of the 3 phases from your converter should hook up to 2 wires from the motor.
    Line 1 connects to T1 and T7
    Line 2 connects fto T2 and T8
    Line 3 connects to T3 and T9
    connect T4, T5 and T6 togeter and tape off.
    Thats about all I remember...please be safe if you give it a try.
    Mar 2009
    17
    Take it to a good motor shop they can figure it out. Most effective way.
    Mar 2009
    17
    Those copper clips should be the wire numbers look close seen it done that way many times 1-9
    24221
    They sure look like the ID bands to me, have you tried really cleaning them off?
    This is a list of most motor connection details if you try and reverse engineer it.
    Connections
    Nine connections is usually the typical double star connections for either 240/460v operation (parallel or series star).
    Al.
    Albert E.
    Jul 2007
    37
    Can you shoot me some more info ; the exact mill name,type and year ?
    Jun 2005
    91
    Thanks guys. I can't say that I am 100% sure the labels say nothing. I need to clean them. I looked at the tags yesterday and didn't see any obvious writing on them. I will check when I get home.
    Jul 2010
    369
    Using the img below verify the setup
    see image below look at the WYE configuration this is most likely what you have.
    You can verify this with a ohm meter
    Jun 2005
    91
    The ID numbers were on the clips. There clips were so dirty that they had to be cleaner quite a bit before the numbers were visible. I can see the wiring on the label, even though it too is barely visible from the fire the mill was in. Thanks!
  1. Bridgeport series 1 and teco N3 wiring
    By cruzin in forum Bridgeport / Hardinge Mills
    Last Post: 10-02-2010, 04:14 AM
  2. Wiring Bridgeport motor question?
    By CATCH22 in forum CNC Machine Related Electronics
    Last Post: 05-14-2010, 04:22 AM
  3. Series 2 cnc 2 hp motor on a series 1 bridgeport?
    By CATCH22 in forum Bridgeport / Hardinge Mills
    Last Post: 11-08-2008, 03:18 PM
  4. Identifying Bridgeport Series 2 Interact 4 Spindle Motor
    By UKRobotics in forum Bridgeport / Hardinge Mills
    Last Post: 05-26-2006, 12:55 PM
