Im using Heidenhain TNC in my mashine and to change the S parameter i need to output:
123 TOOL CALL 1 Z S2000
at the normal toolchange
or later a
456 TOOL CALL S3000
line when the speed changes.
my problem is that if i change the speed between different instructions but still using the same tool I don´t get a new tool call
I think in ISO you just add Sxxxx on a normal line and you are done.
I guess there are two solutions.
one is to force a toolchange at every speed change
and one is to check if speed is not = old speed and then output my new speed value.
Does anyone have a solution or atleast a hint to offer?
