586,082 active members*
3,937 visitors online*
Results 1 to 7 of 7
    Apr 2008
    211
    Battery charging??
    Hello boys n girls!
    I have the Colchester Storm a-50 lathe model with Fanuc 21iT.I have not run the machine for a while and I was wondering about my x and z axis batteries going dead.Are these batteries rechargable and get recharged when the machine is running or are they like your regular flashlight bats and just get changed when they run low?They are Panasonic lithium BR-2/3AGCT4A 6V with 4 batteries in the pack.
    Thank you
    Feb 2009
    6028
    Lithium, not chargeable. Very expensive. I made a lot of money in the past installing the fanuc D cell battery boxes. Worth while upgrade, once the lithium batteries go, it about 75 bucks for the batteries + overnight shipping- so ~100 bucks every year or two. The battery boxes were 60 bucks, about an hour to cut and mount in the machine, and 10 bucks a year from your local grocery store.
    Apr 2008
    211
    D cells!!?Now why didn't I think of that!That's brilliant indeed.
    So if they are not rechargeable then letting the machine run now and again won't do a thing?(chair)
    underthetire you are awsome!!Thank you so much for the info.
    Feb 2009
    6028
    Not for the batteries, but it's good for the slides to get moved around. It will keep things lubed, loose, and ready to go.
    PS, I have seen guys put those 6volt lantern batteries in the machines to. The fanuc box was just a little cleaner.
    May 2010
    83
    Quote Originally Posted by underthetire View Post
    Also, remember that when changing the batteries, make sure the machine is on... otherwise it will dump the axis memories... I learned the hard way. . . :withstupi
    Apr 2008
    211
    He he!Thank's for the warning but I already knew about that one.Friday I went and picked up the goodies to switch over to D cell alkaline batteries.When I get around to it I will try and post the mod that I came up with.So far about $30.00 bucks spent.
    Apr 2008
    211
    So this is what I came up with for 30 bucks.Thanks a lot again.
    Zen:cheers:
    Attached Thumbnails Attached Thumbnails IMGP5390.jpg   IMGP5391.jpg   IMGP5395.jpg   IMGP5392.jpg
  1. Acramatic backup memory battery charging problem
    By cnc1000 in forum Cincinnati CNC
    Last Post: 03-17-2010, 07:00 PM
  2. Solar power for charging USB devices and recyling
    By Shotout in forum Environmental / Alternate Energy
    Last Post: 06-30-2009, 04:37 AM
  3. battery alm
    By Drye-123 in forum Fanuc
    Last Post: 12-18-2008, 03:26 PM
  4. Super charging.
    By MrWild in forum Stepper Motors / Drives
    Last Post: 10-25-2005, 12:29 AM
