586,077 active members*
3,591 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas VF6 Z axis drops .025" during cuts.
    Sep 2010
    Question Haas VF6 Z axis drops .025" during cuts.
    We have a Haas VF6 that drops .025" in the Z axis during cutting without a change in the Z position shown on the control. Once the Z axis drops that
    .025" it doesn't change any more.
    Dec 2010
    154
    If you're certain you're not sucking a cutter, it sounds like your Z axis motor is failing. I had a similar problem a few years ago with my VF3. The service tech put a new motor in and that was that.
    Oh and a $1200 bill later...
    Nov 2010
    Check the belt if it has one, for tension and condition. Check there is any wear in the pulley or coupling.
    Is the axis brake sticking on ? it could be holding the axis until it releases (check the brake relay is good).
    Check the feedback unit (encoder) on the motor or end of ballscrew connections are tight. Make sure the motor and the ballscrew nut screws are tight. Check the counterbalance weight (or Cylinder) system is ok (free and working).
    Finally, measure the axis for backlash. In handwheel, in 0.001" pulses, how many clicks do you need in either direction till it moves ?.
    If the mechanical checks are all ok, the problem then has to be electronic, possible fault with axis encoder or axis board.
  1. "Cheap" CNC Mill that cuts steel?
    By parcheezy in forum Open Source CNC Machine Designs
    Last Post: 09-02-2010, 06:23 PM
  2. Thread Milling using "C" axis no "Y" on the machine
    By tejano4life72 in forum Mori Seiki lathes
    Last Post: 07-19-2010, 08:59 PM
  3. Cutting 1/4" acrylic - perfectly perpendicular cuts possible?
    By jeanyes in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-29-2009, 11:53 AM
  4. Axis feed rate drops to zero then back to normal
    By TurboBlazerX in forum Fadal
    Last Post: 03-20-2009, 02:52 PM
  5. Looking for 24" of Acetal/Delrin (or drops) - Suggestions?
    By scorpion in forum Glass, Plastic and Stone
    Last Post: 02-25-2009, 10:58 PM
