I started a new job 6 months ago at a shop that uses all mazak mills. The guys that have been running these machines for years have never looked into parameter issues that constantly cost them time and money.
In this time I've come up with a little list of things i'd like to know if anyone here can point me to the right parameter, if there is one. So here goes, broken down by machine. We have three machines but most of these issues need to be corrected on all of them.
20+ year-old AJV w/ M-32 control
1-I'd like the Position screen to always default to the command screen, like our other machine does, which is a newer VTC w/ M-PLUS control
2-we always use rigid taps and I always have to set the tap data to 1 for rigid and 100 for return feedrate, I'd like this to be the default when defining taps
VTC w/M-PLUS control
1-When changing any part of the tool data, for instance: .5A endmill to .5B endmill, the tool length is erased automatically. I wish it would quit that.
VCN w/Matrix control
1-When using a line or face unit, the tool always pauses for a moment before any change in direction. This is happening hundreds of times each cycle for a part being machined this week and its unnecessary. I need to know how to make it move continuously.
2-When a machining unit has an initial depth of say Z-1., the tool will only retract to .125" above that depth for repositioning to the next pass. So it'll crash into the side of the part at a depth of Z-.875 instead of retracting to the programs initial Z which may be Z4.0. We can change this in the TPC for each unit that needs it, but I'd like this to be the default for all machines and all type of machining units.
That's it for now but the list keeps growing.
I greatly appreciate any help you guys might be able to give me
