586,043 active members*
3,631 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > G&L Ram630 X Axis Reference Problem
    Dec 2010
    The Ram 630 has a homing procedure you must go through for each axis after the machine has been powered down. You select the axis and it proceeds minus to a positive stop and then moves to zero. the x Axis goes to the stop and faults out with a servo excess error. In fanuc this is a dog-less homing method but in G&L I'm not sure what it is or where to look for parameters in the control.Has anyone had a similar problem and could possible give me a heads up on this? I have removed the way covers and there is no limit switch nor any obstruction.
    Thanks,Bruno
    Re: G&L Ram630 X Axis Reference Problem
    hi
    Can you tell me step by step what happen on your Machine ?
  1. Heidenhain 155 - Z axis reference problem
    By Teejaycasa in forum Uncategorised MetalWorking Machines
    Last Post: 12-19-2012, 10:06 PM
  2. 5t reference problem
    By bigalow in forum Fanuc
    Last Post: 04-17-2012, 02:54 AM
  3. Weidemann C2000q Reference Problem
    By vandl in forum Uncategorised MetalWorking Machines
    Last Post: 02-17-2011, 04:48 PM
  4. Weidemann C2000q Reference Problem
    Last Post: 02-16-2011, 02:13 PM
  5. Fanuc21i-T - Reference point problem
    By Dare in forum Fanuc
    Last Post: 01-22-2009, 11:04 PM
