586,036 active members*
4,068 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Connect Fadal 2016L to a computer (edgecam/artcam)
Results 1 to 8 of 8
    Dec 2008
    441
    Red face Connect Fadal 2016L to a computer (edgecam/artcam)
    Hello, im from norway, so try too use easy words
    I just begin in a new company for 9 days ago. I run a fadal 2016L machine, and i have learned some stuff.
    But now i want to connect a computer to the machine and send some files.
    Is it a program for free? (my company pays, but i want it fast! )
    I use a little bit artcam and starting to use edgecam..
    Does someone know where i can get a postprosessor for artcam to fadal?
    I haven`t installed PP before, so im a beginner
    Greetings from Robert.
    My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
    Jan 2004
    3154
    We need to know what controller you have on it
    www.integratedmechanical.ca
    Dec 2008
    441
    Ok, where can i find out that? open the door on the right side? and what card is it?
    Jul 2009
    317
    SIDE CABINET (CNC BOX) RS232 CONNECTOR; sOME HAVE USB OPTION
    Dec 2008
    441
    Ok, i look there tomorrow
    Thanks!
    R.
    Jan 2004
    3154
    Type of control will be advertised on the front of the panel (Fanuc, Siemens, 88, 88HS, MP32, Fagor, etc).
    Sep 2007
    99
    If it is RS232 you only need to know baudrate, parity, bit's(ex 9600,8,1,N) and maybe handshake.
    Use an normal FTP prog and send it have done that on several machines in the old day's.
    Lykke til :-)
    Runar Holm, Norway
    www.maxmekker.com
    Feb 2007
    171
    Vegabond,
    We also have a full RS232 troubleshooting checklist which not only helps you connect, but shows you how to troubleshoot your Fadal as needed and check your cable configurations. I have attached the doc. We carry all the cables and connectors you might need and our software, FadalCNC-DNC can communicate with any control. The major differences between the Fanuc and Fadal controls is the cable wiring, however if you wire the cable for a Fanuc control it works perfectly on a Fadal control....all of them (CNC88, CNC88HS & 32MP....and the Fanuc of course).
    Here is a link to the proper pinout to use for this application:
    RS232 Pin Configurations
    If you need further assistance, I know RS232 very well and can help you through about anything.
    Good luck!
    Brian D.
    FadalCNC
    Attached Files Attached Files
  1. ArtCAM Computer Performance WORKSTATION VS END-USER PC
    By Lafaso870 in forum Jewelry Design Software
    Last Post: 11-12-2010, 09:36 AM
  2. Connect CNC Machine To Your Computer Wirelessly
    By WCSC in forum News Announcements
    Last Post: 07-27-2009, 04:02 PM
  3. What is the difference between an industrial computer and a normal computer?
    By Apples in forum Controller & Computer Solutions
    Last Post: 09-18-2008, 10:27 PM
  4. Replies: 1
    Last Post: 09-27-2004, 04:10 AM
  5. fast computer as server, slow computer as terminal
    By replicapro in forum Computers / Desktops / Networking
    Last Post: 07-01-2004, 08:05 PM
