586,100 active members*
2,749 visitors online*
    Feb 2008
    9
    Mazak m plus control Parity error
    Hello add this happen back in 2009 and it went away
    and now its back and need to find out what my be the cause of it
    its kind of funny how this happens but I can make it happen every time i do this
    step one open a program and try to use the auto set for the speeds and feeds
    hit it once and all is fine go back and try it again and Wham out goes the control and the screen show what is in the first pic Parity Error
    then when i restart it as error 2nd pic 411 Power off during program edit
    pic 3 is in program at the point before the control shuts off
    pic 4 is the auto set button for the speed and feeds
    pic 5 is hardware alarm screen
    pic 6 is alarm messages
    and if the machine is not at home 1 it will not find zero again in less you
    manually move the ball screws to the limit switch in x y & z with the power off
    because the end coder thinks it at zero
    is there away to move the servo past zero as where the encoder thinks it is at. manually
    thanks for your time
    speed
    Attached Thumbnails Attached Thumbnails MVC-486X.JPG   MVC-492X.JPG   MVC-489X.JPG   MVC-490X.JPG
    Jul 2007
    284
    Your program area might be corrupt. Can you back up your programs? If so you might want to try to format the program area. To do this just do an "all erase" under the program button. Take caution though as this will delete all of your programs.
    Feb 2008
    9
    Quote Originally Posted by onthebumper View Post
    I think I got it
    spent the whole day on and off the phone with mazak service
    I got it down to the tool file is corrupt
    is there a way to print out the tool file so I can reinstall by hand
    I have camware by mazak
    and been using hyper terminal so the file is in a .txt but it all garbled
    thanks Speed
    Oct 2003
    321
    Re: Mazak m plus control Parity error
    got now the same problem.
    How did you manage it?
    Best regards
    mazak-user
    Feb 2008
    9
    Quote Originally Posted by mazak-user View Post
    Best regards
    mazak-user
    there is a bug in mine if the tool file gets to big it will do it
    even changed out and add New memory still dose it
    the best fix that i did is to keep the tool file small
    The tool file is the place where you store all the tool sizes depth of cut diameter & flutes end mills ball endmill face mill
    hope this helps Speed
  1. Fanuc error 998 ROM Parity Error ???
    By ED209 in forum Fanuc
    Last Post: 02-07-2022, 10:02 AM
  2. Mazak parity error
    By Darth Yoda in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-22-2013, 02:43 AM
  3. Replies: 0
    Last Post: 11-26-2012, 09:03 PM
  4. Mazak M32-Parity H Error
    By compuslave in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-04-2009, 10:25 PM
  5. Ram Parity Error
    By rags in forum Fanuc
    Last Post: 12-19-2008, 09:03 PM
