586,047 active members*
3,784 visitors online*
    Feb 2005
    344
    DIN 3 Rail & Wire Duct Screw Sizes??
    What size and type of screw should I use for my DIN Rail and Wire Duct? Attaching to metal. I think I would prefer self tappers, but any recommendation is good.
    I want to order some at the same time I order the rail and wire duct.
    24221
    You can use self tapping, personally I use #10-32 Robertson head, and tap the back panel, I am not sure how popular or available Robertson is in the U.S.
    I prefer the aluminum DIN rail as it usually has the mounting slots in it already.
    Al.
    Albert E.
  1. Caps for screw on linear rail
    By millman52 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 04-21-2009, 02:42 PM
  2. power supply size? for multi wire (total 250 inches of wire)
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2009, 11:34 PM
  3. K2 rail & screw grease
    By leo.dearden in forum K2CNC
    Last Post: 02-27-2008, 03:55 PM
  4. Suppliers for wire carriers and Ball screw
    By ralbery in forum Want To Buy...Need help!
    Last Post: 01-28-2008, 06:21 AM
  5. CNC for a/c duct liner
    By WMACS in forum Open Source CNC Machine Designs
    Last Post: 10-02-2007, 07:18 PM
