586,055 active members*
4,277 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Toolchange problem
    Nov 2010
    10
    Toolchange problem
    I want to do a tool call for different ops when im using the same tool,i have 4 different ops one after the other using the same tool but i want to be able to go to each op when seeing the job through,but in mastercam mill 9 it wont do a tool call at each op,it see's it as a null toolchange,ive tried to adjust settings in the post but have had no luck,can anyone advise what to do thx
    May 2008
    667
    On the tool dialog box where you input tool number, feed, rpm etc, just check FORCE TOOL CHANGE just under the plunge rate input box.
    Hope this help.
    Jeff
    Nov 2010
    10
    Many thanks Jeff,ive beem messin about with that for days, i knew i could rely on someone on cnc zone.
    Regards Adrian
  1. HAAS VF0 toolchange problem
    By lapokerplayer in forum Haas Mills
    Last Post: 05-25-2022, 08:36 PM
  2. Replies: 7
    Last Post: 01-04-2018, 09:22 PM
  3. Toolchange
    By zooloader in forum Okuma
    Last Post: 11-04-2010, 08:48 PM
  4. MV-55 Toolchange problem
    By Basspilot in forum Mori Seiki Mills
    Last Post: 04-03-2009, 09:58 AM
  5. Problem with toolchange in Mazak Quickturn nexus II
    By Legenden in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-31-2009, 08:36 PM
