Originally Posted by
bobeson
During my first year of owning a new PCNC1100, I found that all three axis couplers needed to be tightened; I would recommend that owners go and perform this step proactively. I've read numerous other stories of people having coupler issues because of loose bolts. In addition, I found that the six bolts holding my spindle cartridge onto the head casting were loose and causing problems. Once I tightened these all up, I haven't had any further problems with them, which leads me to believe that either the factory was not correctly torqueing the fasteners, or the assembly torque specs are too conservative (low) for the application.
While you're tightening up your couplers, it's a good idea to get familiar with your gibs adustments too - optimizing these can make the machine operate much more smoothly if it seems to be getting a little rough. A true optimization is something I don't know how to do properly, but following Tormach's "open-loop" adjustment procedure and iteratively trying a few tweaks here and there has led me to noticably improved performance twice now. I also tweaked the gibs once without any improvement, but that time it turned out that the roughness was caused by my way oil reservoir running empty without my noticing, so the ways had lost their lubricating film for a short while. D'oh! No harm was apparent though, and once I relubed the machine it was all good.
