586,108 active members*
3,100 visitors online*
    Oct 2007
    1025
    loss of z axis control
    Just some info from an experience.About a month ago my z axis would not respond to the keyboard command,then a giggle here or ther and it would work.
    Bit scarey as this could quit during a run and really mess things up.
    I tightened every mar connector on the z motor and checked the z drive ,all was well and it would work for awhile .Finally it quit no z at all.
    I suspected the DB25 soldering but it turned out its a bad wire or loose common at the z drive .
    Its a short piece about 4 in and i am going to replace it shortly .
    This problem hung around for some time and was difficult to pin down.
    Oct 2007
    1025
    z axis
    turned out it was the gecko drive terminal block not a loose wire,had to unplug the block and re plug it in
    Z axis ok now
  1. X3 loss of spindle speed control
    By binfordw in forum Benchtop Machines
    Last Post: 03-09-2010, 07:42 PM
  2. control loss or glitch gorilla cnc
    By woodman08 in forum Gorilla CNC Machines
    Last Post: 01-28-2009, 03:02 PM
  3. Loss of low power control. Any suggestions
    By Strelitzia in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-16-2008, 09:56 PM
  4. Replies: 6
    Last Post: 05-27-2008, 02:55 PM
  5. Axis Loss Detection (Gecko)
    By bill south in forum Gecko Drives
    Last Post: 11-04-2005, 03:00 PM
