I was using a tb6550 board from hubbard but it keep missing steps and some of my steppers would get hot some would stay cool all at 75% amp. So recieved a g540 for christmas and I thought my troubles were behind me. Though it is better I am still missing steps both in 2d and 2.5d. I even build a new cnc with better bearings and is very easy to turn each threaded bolt by hand.
I am Waisting my time and wood$$ I have spent several hrs and tuning motors and reading forums looking for answers. I have contacted Gecko but they just tell me slow down the machine but it still looses steps. More evident in x and y cnc project is history after waiting hour or so i have to start over just try again it happens at different times during cnc project. It pauses some times but I am not sure why and then it continues ok. others totals project
Here is my set up I have tried 2 different computers 1 a dell 2.4 with xp 2gigs ram and compaq 2.8 with 2 gigs of ram both desktops. My both in epp mode and mach 3 ver r1.83.027. i have loaded file for mach 3 from gecko. steppers 2amp 24v 6wire minbea motors wired full, tuned at vel 35, 6accl, step pulse 2 set to run reverse on my setup. 6.4amp 24v powsup When running it has some power takes alot of effort to stop threaded bolt from spinning. gecko tells me my setting are two high but i can take acc up to 90 setting wave a 45 degs. and then it starts loose right away by just jogging cnc. I put mach3 in sherline mode 35hz to see of it helps but still same problem.
I create my designs in corel draw and export to WMF import to lazycam to scale and produce g code. I have also used cambam and Freemill with mach3in and Mach3sherline all with same result. Every now and then i get lucky and the project is finished.. I should just be able to position wood and comback later to the finished job.
If anyone can please HELP ME WITH SOMETHING TO TRY THAT Could fix this problem. I DONT KNOW WHAT TO DO ANY MORE.. at times i just want to give up. I think something is just not set right and i am not realizing it.
Any help is greatly apprecated.
Thanks for reading this post hope you can help!
