IMService has released a fully assembled 4 axis servo driver
system. The SYS-4 utilizes the DeskCNC SV-500 servo driver, rated
at 5 amp and 30 vdc. Works with permanent magnet, DC servo motors
with incremental, ttl level quadrature encoders.
Compatible with most step and direction parallel port indexers, the
system ships with pin compatibility to the Sherline step and
direction drivers ( EMC ).
Units have power breaker and cooling fan, panel connectors for servo
encoders, and a 12 foot motor power cable is included.
Typical applications include desk top CNC milling machines such as
the Sherline, Taig, Max NC, Desktop CNC Routers, Foam cutters,
plasma, and imported mini and micro mills.
Retail price is $599. The SYS-4 is available through July 31st, at a
special promotional price of $549.
http://www.cadcamcadcam.com/index.as...ROD&ProdID=110
If you have some servos laying around and don't want to spend a
fortune to put them to use, this is the system for you.
These products as well as other new CNC systems and components will
be on display at the Iron Fever Model Engineering Exhibition at
York, PA, USA on August 12-14th, 2005. See you there.
Fred Smith - IMService
http://www.cadcamcadcam.com/hobby
