586,121 active members*
3,056 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > CNC (Mill / Lathe) Control Software (NC) > If you could replace your CNC mill controller with anything...
    Dec 2010
    201
    Okay - here's the scenario... You just got hit by lighting, the crackheads showed up with a forklift, or the zombies chewed through the cables - whatever... What you had is no longer working, and you can replace it with anything you pick... What would you chose?
    We're getting another Shizuoka AN-S with a toolchanger up and running after being stored for a bit... We plan on replacing the servos at the same time we buy a control.
    Feb 2009
    6028
    Anything? Fanuc 31i, super Nurbs with a Mori Maps iv front end. Obviously not practical for this application but you did say anything.
    Been playing with Mach 3 myself. Other than the cartoonish screens, seems pretty powerfull. I'd probably do that one if it was a hobby machine for myself.
    Oct 2005
    1237
    Why are you replacing the servos. Are they worn out? What is your budget?
    Dec 2010
    201
    Servos aren't worn out - I think the boss is just looking for a "plug 'n' play" sort of solution, and I think he had a bad experience hooking up an AB 8400MP a few years back. The ones that we're taking off are Tamagawa resolvers for the table (haven't looked at Z yet...). It's a pretty stout machine, and won't be used in a "hobby" fashion - we're trying to increase output beyond our existing Shizouka AN-S and our Milltronics Partner X...
    Mar 2008
    shizouka AN S
    I have a Shizouka AN S Mill with a Fanuc 6M control. I just installed it in my shop after being stored for 2 years and upon startup it gives a 401 servo alarm. Z servo used to blow fuses on heavy cuts or overtravel. Going to check the servo motor. Would you have any advice for troubleshooting this 401 alarm?
  1. multicam controller repare or replace?
    By daisydog in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-02-2014, 03:32 PM
  2. Looking to replace the lathe and mill bearings
    By bprager in forum Shopmaster/Shoptask
    Last Post: 04-08-2008, 02:10 PM
  3. H-Square controller.replace/repair
    By graver1 in forum Engraving Machines
    Last Post: 08-08-2007, 10:00 PM
  4. CNC-mill controller.. which?
    By TechGraphix in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-05-2006, 01:05 AM
