586,060 active members*
3,506 visitors online*
Results 1 to 6 of 6
    Jan 2011
    Bob cad Crashes
    Recently BBC v23 will not start on my HP laptop. Its running Vista so I had already switdhed to an earlier version, Its been running for over a year but suddenly it stopped. I get a message that and error has for BBC to close, I've reloaded the program to no avail.
    any ideas?
    Mike
    Sep 2010
    145
    Make sure its running under the compatibilty mode, old slow window system
    Jan 2011
    compatibility
    I was running it at windows 2000/me, but since it started I've tried all the other options. The program runs on my friends ibm with vista no problem. Have you tried windows 7?
    Sep 2010
    145
    Yes Ive got it on a xp and a windows 7, need to set it to run under the old 32 bit system though. (on win 7) I have a me machine also but have never put it on that one. I have the me machine hooked to a vinyl cutter and its buggy enough running that cutter software, (china made).
    For me it seems the V23 is most stable on win 7 than on XP.
    I see they quite supporting me a while back so if theres something new in BC that needs some modern eqlvc it might be a problem.
    Feb 2009
    2143
    Runs fine on Win 7, you just need to set it as "Run as Administrator".
    Dec 2008
    4548
    Quote Originally Posted by mcphill View Post
    Or, if your not hooked up to the internet, just turn off UAC.
  1. BobCAD V23 Crashes
    By noyloj in forum BobCad-Cam
    Last Post: 01-09-2013, 05:17 PM
  2. Does your BobCad crashes or is me?
    By Ed from NY in forum BobCad-Cam
    Last Post: 07-14-2009, 02:38 AM
  3. crashes
    By pyroshizzness in forum Uncategorised MetalWorking Machines
    Last Post: 03-13-2009, 06:27 AM
  4. Strange FMS Crashes
    By Old Dave in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-04-2008, 12:32 PM
  5. crashes and destruction
    By planar39 in forum Uncategorised MetalWorking Machines
    Last Post: 01-04-2007, 05:26 AM
