586,108 active members*
3,052 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Trying to use an automotive Sun Pro tach on a spindle but can't get a tach trigger.
    Mar 2009
    296
    I'm trying to use an automotive tachometer from sun pro on the spindle. I've got 12 volts to the tach, put magnets on the spindle and am running the trigger wire through a solenoid coil with a piece of steel through it. I'm not entirely sure if the other end of the solenoid coil is supposed to go to the ground or a + 12 volts. Someone told me I may need to have a diode on it. What else can I try?
    24221
    Not exactly sure what you have there and what you are trying to do?
    What purpose is the 'Solenoid coil with a piece of steel' ?
    If you want a spindle tach you could look at a automotive timing gear tooth sensor these do not require magnets to operate.
    Al.
    Albert E.
    Mar 2009
    336
    Quote Originally Posted by slashmaster View Post
    What model is the Tach? It is possible that the sensing system for your tach won't work for what you are doing. The user manual should tell you how to connect it.
    "Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away." Antoine de Saint-Exupery (1900 - 1944)
  1. Spindle tach
    By JpBinc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-29-2009, 06:57 PM
  2. Spindle Tach
    By JpBinc in forum CNC Machine Related Electronics
    Last Post: 03-08-2009, 03:12 AM
  3. Spindle speed and tach for MACH3
    By chrispy in forum Mach Software (ArtSoft software)
    Last Post: 04-05-2008, 02:25 PM
  4. Tach kit
    By mark c in forum CNC Machine Related Electronics
    Last Post: 10-12-2007, 10:50 PM
  5. diy tach
    By swarfmacdaddy in forum CNC Machine Related Electronics
    Last Post: 01-29-2006, 06:57 PM
