586,469 active members*
2,980 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > G540 / Smooth Stepper and an E Stop
    Mar 2005
    335
    Thumbs up G540 / Smooth Stepper and an E Stop
    I am trying to get my G540 drive to work with the smooth stepper. The issue that i have is when i start the mach and the smooth stepper the e stop input won't clear due to the charge pump not firing up because mach won't start the smooth stepper due to the estop.
    I am using the error line on the G540 as the E-stop input at the moment.
    I know everything is working as i can disable the E stop and no problems. Effectively i need to delay or over ride the estop untill the smooth stepper generates the charge pump signal.
    Apr 2005
    861
    You need an enable button as a temporary override for start-up. I use a simple PTM momentary switch. Sequence is Mach on, controller power on, press enable and clear Estop condition in Mach. Then you are rolling.
    LongRat
    www.fulloption.co.uk
    Mar 2005
    335
    i did try and ring you! obviously getting ready to watch top gear
    Mar 2005
    335
    Posting on the Mach Forum there is a setting on the general page that allows the generation of the charge pump signal while the e stop is engaged. I always thought there would be a software solution. Many thanks for the help.
  1. G540 and E-Stop
    By dpgoldberg in forum Gecko Drives
    Last Post: 05-11-2018, 08:17 PM
  2. G540 E-stop and Mach3
    By Astroguy in forum Gecko Drives
    Last Post: 02-03-2012, 05:10 AM
  3. Disapointment with first gen g540 and Smooth stepper
    By Fixittt in forum Gecko Drives
    Last Post: 10-20-2010, 10:39 PM
  4. Mach 3 setup for G540 & Smooth Stepper
    By jefftomerlin in forum Mach Software (ArtSoft software)
    Last Post: 07-31-2010, 06:56 PM
  5. G540 e-stop question
    By vintageracer in forum Gecko Drives
    Last Post: 01-04-2010, 11:45 PM
