586,094 active members*
4,033 visitors online*
    Jun 2009
    110
    Work offset question
    I know this is a basic question but when I saved a work offset in Mach 3 and gave it a name how do I retreive it??. The work material is indexed to the table with two pins so I can do more than one run. I'm not sure the process to get back to the saved work offset whan I have changed the cordinates for something different. Any help out there.
    I know this is a basic question but when I saved a work offset in Mach 3 and gave it a name how do I retrieve it??
    A more important question, is how did you give it a name?
    Work offsets are numbered, G54-G59, then G59P7 -G59P254.
    They are stored in a tanle. When you save the offset, you save the table. You can't give it a name.
    Jun 2009
    110
    OK, Now I understand! Just know the G# and go back to that. Got it
    Thanks again for your help
  1. Work/toolpath offset-Question..
    By CyborgCNC in forum Mastercam
    Last Post: 03-14-2010, 09:42 AM
  2. work offset
    By Claude Boudreau in forum BobCad-Cam
    Last Post: 11-23-2009, 12:41 AM
  3. Daewoo EZ-Guide Work Offset Question.
    By kjetton in forum Daewoo/Doosan
    Last Post: 05-29-2008, 12:53 AM
  4. Work Offset Question
    By Cartierusm in forum Mach Software (ArtSoft software)
    Last Post: 11-29-2007, 10:50 PM
  5. work offset in fanuc 6m b- help
    By rags in forum Fanuc
    Last Post: 08-04-2006, 03:39 AM
