586,546 active members*
3,470 visitors online*
    Jul 2009
    28
    Old Bronx CNC Press Brake
    Working on a old Bronx 25-15-CNC/VDU press brake and I cannot get the machine constants to store. When trying to save these I get a "STORE FULL" message even though there are none stored. Programs and reference positions store fine. I disconnected the battery to clear the RAM and it still comes up with the same full message. One other thing there is a led on the CPU board that says "MEM PROT" and it is on, not sure what that means.
    Any help would be greatly appreciatted.
    Geoff
    Dec 2007
    32
    Most likely that is a memory protect button... It's there so you cannot change anything unless it's off... You should have a memory protect key on the faceboard somewhere you need to turn that off in order to change your values.
    Jul 2009
    28
    Thanks, I found a guy in England that knew that machine well and the fix was" From the menu press 4 then 2 then LM the screen will show fault this should clear the memory but make a note of the constants and tool references as you may loose them,you will loose all programs"
  1. Looking to buy Used Press Brake
    By magma-joe in forum Bending, Forging, Extrusion...
    Last Post: 01-16-2012, 09:05 PM
  2. Press Brake
    By BROWNI in forum Bending, Forging, Extrusion...
    Last Post: 01-08-2011, 04:12 PM
  3. Selecting Press for home shop press brake
    By tikka308 in forum Bending, Forging, Extrusion...
    Last Post: 12-29-2009, 05:51 AM
  4. Press Brake
    By davesnd in forum CamSoft Products
    Last Post: 12-02-2009, 07:11 AM
  5. NorthStar Press Brake For 20 Ton Shop Press anyone ever use one?
    By dsmdude in forum Bending, Forging, Extrusion...
    Last Post: 04-13-2007, 10:01 PM
