586,117 active members*
3,510 visitors online*
IndustryArena Forum > CAM Software > UG NX > cutter compensation
    Apr 2010
    16
    cutter compensation
    Hi please can anyone help? I have some training coming but cant wait and want to play. all the tool paths that I post are missing cutter comp.(g41/g42) what am I doing wrong?
    do I need to use tracking points in tool setup?
    How?
    Feb 2006
    146
    On the Non-Cutting moves dialog click the More tab and activate the Cutter Comp.
    It depends on how you intend to use cutter comp if you need to use the tracking point.
    When you are using the system as designed, meaning you specify the tool size in NX and at the machine the value in the cutter comp is the diference between the programmed size and the actual measured size of the tool, usually a small value then you don't need thetracking point. It is at the tip and center of the tool.
    If you intend on entering the size of the tool at the machine in the comp table then you will need to use the tracking point at the tool diameter. Not my personal choice.
    John Joyce -NC Programming Supervisor
    Barnes Aerospace, Windsor CT
    Apr 2010
    16
    Thanks so much. it's so much easier when you know what you are doing, I have looked nearly everywhere for that button and never would have thought to look there.
  1. Cutter Compensation
    By Southbend Sam in forum Dynapath
    Last Post: 11-30-2010, 10:07 PM
  2. Cutter Compensation
    By TravisR100 in forum NCPlot G-Code editor / backplotter
    Last Post: 10-31-2010, 08:09 PM
  3. Cutter compensation..
    By driftmaster in forum Mastercam
    Last Post: 04-03-2010, 08:14 PM
  4. Cutter compensation????
    By Clawsie Machine in forum Cincinnati CNC
    Last Post: 11-13-2008, 08:19 PM
  5. Cutter compensation?
    By Tonenc in forum G-Code Programing
    Last Post: 11-03-2005, 06:53 AM
