586,112 active members*
3,078 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > Employment Opportunity > RFQ small aluminum pieces both mill and water/laser jet parts
    Sep 2010
    46
    I need to have the following parts made for an assembly that I am selling. A friend machined these for me previously but has since got out of the business.
    The numbering (name) of the parts is based on their order in the assembly.
    Part #3
    I need a quantity of 4 to complete the assemblies I have started. Any aluminum alloy will work. We used 5/8" x 1.5" bar before.
    The image shows two 1/4-20 tapped holes on the front, these are duplicated in the rear but are not visible.
    Part #4 is a very simple water jet or laser jet part it could also be milled as well.
    I also need a quantity of 4 of these to finish the current assemblies.
    1/4" aluminum plate any alloy will work.
    Parts need to be free from burrs and need to have finished edges all the way around (no rough saw cut edges; would think this would have been obvious but from previous work completed by a machinist on here it may not be). The edges may be the raw aluminum bar were applicable as long as its smooth.
    I can provide IGES or STEP files on request. Let me know if there are any other questions.
    These parts are part of a larger assembly as I mentioned before this is a newer design than ones I have sold previously. If they work and sell as well as I hope they do then this will likely turn into a reoccurring order.
    You may quote either part individually or combine them together. I would prefer to deal with one supplier/machinist if possible. Please include shipping to 44224.
    Thanks.
    Sep 2008
    277
    pm sent
    thanks
    Jun 2007
    16
    I see that you are from Ohio. I am a shop here in Newark Ohio interested in quoting your work for you and develop a working relationship. Visit my website www.newarkprecision.com
    Sep 2010
    46
    This job has been awarded thanks for all who bidded on this.
  1. RFQ: Mill and Laser/WJ Work, 2 Aluminum Parts
    By kend in forum Employment Opportunity
    Last Post: 07-10-2015, 01:46 PM
  2. RFQ for 30 - 60 thousand small aluminum pieces.
    By porterico in forum Employment Opportunity
    Last Post: 01-13-2011, 02:35 PM
  3. Small Aluminum Parts Mill Work
    By ahaidet in forum Employment Opportunity
    Last Post: 10-28-2010, 04:42 AM
  4. RFQ Aluminum parts for small CNC mill
    By southernexplore in forum Employment Opportunity
    Last Post: 10-02-2009, 05:08 PM
  5. Small Aluminum rectangle pieces
    By TMaster in forum Employment Opportunity
    Last Post: 09-29-2008, 11:49 PM
