586,523 active members*
3,403 visitors online*
Results 1 to 6 of 6
    Dec 2010
    Wiring question
    Hey guys. So I need your expertise again I have three of these steppers 1.8DEG. 3.6V SIZE 23 STEPMOTOR-MPJA, Inc. and the hobbycnc EZ board. The steppers have 6 wires. Can someone please help me figure out how to wire these? The only information I could find didn't fit my board so I'm kind of lost. Also, is there a way to test if the wiring is correct? I haven't put the chips in my board yet.
    Any responses are greatly appreciated!
    Thanks, Beau
    Dec 2010
    Thanks Gerry. I looked at that but the notation is different than the wiring suggested in my manual. At least thats what I think. Here is the manual. HobbyCNC Pro Manual scroll all the way down for the wiring info. They seem to use different lettering. It confuses me but maybe you, being a genius that you are, can figure it out haha.
    Thanks a million, Beau
    Oct 2005
    2392
    6-wire stepper can be tested easily if you have a ohm meter (multimeter).
    They will be in 2 groups, and each group has 3 wires connected together.
    Out of those 3 wires, one is the middle and the other 2 wires are the "phase" wires you need to control the stepper.
    To find which is which, measure the ohms, there will be twice as many ohms between the 2 phase wires compared to the middle wire.
    As another easy method for 6-wire motors, generally if there are 4 coloured wires and a black and white wire, the black and white are the middle wires.
    If you are using the HobbyCNC stepper drivers then the 2 middle wires join together and go to power (motor power) and the 4 phase wires go to the 4 other pins.
    Dec 2010
    Thank you! That helps a lot! This is probably a newbie question but does it matter if the pairs are switched? Like say the b and B wires are in the a and A terminals.
    Thanks Beau
    Jun 2007
    3757
    The motor might run the other direction.
  1. Wiring question
    By rs_customs in forum PlasmaCam
    Last Post: 05-12-2010, 06:33 PM
  2. WIRING QUESTION
    By dcmetalwerks in forum Phase Converters
    Last Post: 06-14-2008, 06:31 PM
  3. New VF-2SS wiring question
    By Matt@RFR in forum Haas Mills
    Last Post: 06-25-2007, 10:10 PM
  4. Wiring question
    By TSJ in forum Servo Motors / Drives
    Last Post: 05-15-2007, 07:20 PM
  5. Wiring Question
    By The Wizard in forum CNC Machine Related Electronics
    Last Post: 01-04-2005, 07:11 PM
