586,055 active members*
4,176 visitors online*
IndustryArena Forum > CAM Software > OneCNC > File importing
    Jan 2011
    30
    File importing
    First before the questions my background.
    I draw in Autocad, usually metric, solid models, almost everything is complex curves.
    Using Alphacam router, at work and for hobby. It will do 90% of what I want (hobby), which is first to produce machine code. Solid model file import very good, not flawless, as if 2d lines are present it gets confused. Very confused, I usually include 2d geometries as reference lines.
    I don't want to draw in anything other than Autocad at this time.
    I have tested a few other CAM programs, and the biggest issue is how a file is imported. That and lack of a 100% working demo.
    I won't buy this type of software without being sure that it does what they writers say. To date every other demo, so called working demo, was either crippled in file import or simply did not import properly. One I tried imported about 1/2 the part.
    My main requirement is native, not a converted file import of a solid model .dwg format file. Far too many errors get introduced in conversion.
    How well does OneCnc do this? Also if I import a solid model can I than alter it in the program?
    Last question for now, if I sent you a dwg file to see if it imports properly, would you test it? Just open it and see if it imports as a solid?
    4826
    We cannot import Autocad *.dwg files into OneCNC, so an intermediate conversion (typically to dxf) would be required.
    As for solid models, yes, you can tear 'em apart if you want in OneCNC. You need Mill Professional or Mill Expert for this capability. OneCNC is a hybrid modeller, so it can deal with surfaces or solids, but not in a parametric sense. Its not really built for so called organic shapes, but if you find a model is missing a surface, it is typically possible to create what is missing.
    Sep 2007
    40
    OneCNC does a very poor job at extracting edges from imported models, being that you are using a router its likely not going to be too big of an issues, but it is not good for machining profiles.
  1. importing .TAP file into Dolphin cam
    By Danno in forum Dolphin CAD/CAM
    Last Post: 09-28-2010, 09:09 AM
  2. importing igs file
    By Cartel, LLC in forum BobCad-Cam
    Last Post: 04-27-2010, 02:39 PM
  3. Problem importing bmp file
    By ChetR in forum Dolphin CAD/CAM
    Last Post: 03-26-2010, 09:03 PM
  4. igs file importing into mastercam
    By hedgehog23 in forum Mastercam
    Last Post: 11-23-2009, 06:13 AM
  5. Importing a DXF or HPGL file
    By wantsout in forum Uncategorised CAM Discussion
    Last Post: 10-10-2007, 09:54 AM
