Hey Everybody,
I am slowly working on my CNC plasma table and would like to purchase the actual plasma unit shortly so that I can use it for a job that I have coming up (use it manually that is)
I would like my cnc machine to cut between 19mm - 25mm of steel/alloy if possible. I have 3 phase power available.
Why do some of the thermal dynamics machines quote a cut thickness for manual cutting then for a CNC cut with the same machine the cut thickness is only about 1/2? do they quote an edge start for the cut thickness manual mode or is it something else?
I was looking at a TD A60 machine that is in my price range, there is also a TD
cutmaster 25 that looks like it can handle 25 mm cuts but could it do this in a cnc setup?
anyone used either of these machines in a cnc setup? any other machine suggestions?
cheers
