586,103 active members*
3,466 visitors online*
    Apr 2010
    Torch is in Lower Limit
    Trying to cut a sign out at work, and when the table goes to cut the "S" out it will throw the error "Torch is in LOWER LIMIT on the pendent. I have try moving the work piece around and still same results. I have copy the "S" and placed it on another sheet and it cut it fine.
    I'm using a Hypertherm THC on a Vicon table with Vicon cutting system software.
    Any help would be awesome.
    Jan 2008
    2247
    It sounds to me like your torch is in lower limit on the z axis slide of the torch height control, which means you may have a low spot on your cutting table and the height control cannot go low enough to maintain the proper height.
    Try adjusting the clamping point on the torch....so that the torch is held lower in the mounting block on the torch lifter assembly.
    Jim Colt
  1. Torch touch off / floating torch
    By Ubatoid in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 01-07-2011, 06:38 AM
  2. Hand torch to machine torch
    By matttargett4 in forum Hypertherm Plasma
    Last Post: 06-01-2010, 09:37 PM
  3. hypertherm 1000 hand torch to machine torch
    By duraflap in forum Hypertherm Plasma
    Last Post: 05-18-2010, 08:34 PM
  4. Different between hand torch& machine torch
    By ltran2000 in forum Waterjet General Topics
    Last Post: 03-02-2008, 04:19 PM
