586,103 active members*
3,667 visitors online*
Thread: Water table
Results 1 to 13 of 13
    Jan 2011
    Water table
    whats normal depth of a water table I am thinking of bulding one for a torch mate 4 X 4
    We usually have the water from the top of the slats, to at least 1" below the slats. Since we typically run a 3" tall slat, this is about 4" deep.
    Mike @ Torchmate.com | www.Torchmate.com
    Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
    Nov 2008
    61
    Are you wanting a water table because you want it to control the smoke and crap or because you want to cut submerged for better cutting?
    If its the latter I can;t help, but if its the former I can tell you that I build a water table 6 inches deep that puts the water 3 inches below the slats (which is what hypertherm said, 6 inches from the torch or it could be damaged. I can tell you this did not help with the smoke and quality of air in my shop. I have since sealed up the sides to the TM2 4x4 table and installed a blower fan which creates a poor mans down draft table, cover all the table around the material to be cut with rubber matting to seal up the top and results in a far superior quality of air. I keep the water table to catch crap but I presume on would not need the water table at all and still succeed in catching the air. Also if you cut lots of AL the hydrogen buildup due to the water table supposedly can reach explosive levels.
    Jan 2011
    Water table
    Mike thanks for the info had drawn at 4.5 deep
    Jan 2011
    PHSS thanks for info do have you any photos of down draft curtain
    Jan 2011
    Water table
    Jan 2011
    Water table
    Got water table filled with water now wont run programs
    Nov 2008
    61
    No pics, cameras broken. I will post pics once I get it fixed or a new one.
    Jan 2011
    Have u cut much 1/2 plate I'm having trouble with slanted kerf I mean over 30 thousand from side to side
    Nov 2008
    61
    yes I have, the bevel could be many things, incorrect cutting speed, nozzle is no longer round or too big, moisture in the compressed air. I have found any one of them causes bevel.
    Jan 2011
    Thanks I have sir dryer and put a new tip assembly on so it must be speed to answer your question on water table air quality is what l am trying to achieve
    Jan 2011
    Nov 2008
    61
    Well a water table will help, albeit not much for controling smoke. sure it catches the slag and prevents it form smoking and collects dust etc but it won't help with most of the smoke. Only a downdraft table will work for that.
  1. What do you do with your water table waste water?
    By turboedgs in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 07-28-2010, 10:33 PM
  2. WATER TABLE
    By pdjcutandfab in forum Waterjet General Topics
    Last Post: 01-16-2010, 09:30 PM
  3. Does anybody know what to mix in the water, on a water table?
    By suzukirmz in forum Waterjet General Topics
    Last Post: 06-22-2008, 05:56 AM
  4. DYNA CNC TABLE WITH WATER TABLE
    By DISCONNECTED in forum Waterjet General Topics
    Last Post: 06-07-2008, 02:04 AM
  5. Water transfer techniques for water table?
    By Knut in forum Waterjet General Topics
    Last Post: 02-02-2007, 04:52 PM
