I was wondering if there is any material that I can cast urethane foam in besides silicone rubber? I want to cut the mold on a CNC and cast with it. It's "straight pull" casting, meaning no undercuts. I'll be casting flexible urethane foam from Smooth-On. I need to find a material that can be cut on a ZenBot router. Aluminum is pretty much out of the question. It would have to be something soft like plastics, wax, or even wood.
This is for a prototype. I don't need to be able to cast many of them and surface finish is not critical.
If this is not possible maybe I can use Smooth On's Soma Foama instead. It's a silicone foam. Any thoughts on that?
Thanks in advance for any info regarding the best mold material.
