Hi all, would anyone have a post processor / code generator for mach 3?
OR, which similar controller post could be used instead of a mach 3 specific to start building one? Say, modify a Fanuc or a Masak post?
Paraman, Parabeast, Paramachine, Parameter.
The many in one and the one in the many.
you can download free generic code files on smartcamcnc.com
smartcams code generators are the easiest code generators to play with. very simple.
you will need the code generation book that should be avail on the site as well.
Delw
Do you have a programming manual with code examples???
I have the org manuals from dos too version 9 .
They should be on smartcamcnc website
Hi, Are you referring to the SmartCam Manuals or the Mach3.
I meant if you have a programming manual for the mach 3 I may be able to get a code generator going.
I have been using Smartcam for quite a while and am now using freeform V17.6.
I am not sure if you can send attachments through the forum here but if you can send it over and I'll take a look.
Ed
Was referring to the smartcam manuals
