586,071 active members*
3,941 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > cheap drill/pin bushing and pin ideas? is there a cheap bushing and pin out there?
    Mar 2006
    168
    Drill bushings can get expensive at $7-10 a piece when you need a bunch of them.
    I'm in the middle of making some part fixturing that will use dowel pins and I'd like to have bushings for the pins in my fixture plates. Is there a cheap source or idea for pins and bushings. I'd hate to use drill bushings if I don't have to since the cost will get pricey quick.
    thanks for any ideas!
    Mar 2006
    2712
    I don't know your application but SPIROL might work(?) SPIROL International Corporation
    Dick Z
    DZASTR
  1. Hardinge Collet, Tap Adapter and Drill Bushing Tray
    By HelicopterJohn in forum Hardinge Lathes
    Last Post: 04-22-2010, 02:54 PM
  2. Bushing Material
    By larry53 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-27-2009, 05:42 AM
  3. Split Bushing
    By KonradyTom in forum MetalWork Discussion
    Last Post: 01-29-2009, 10:32 PM
  4. got any ideas for cheap cad and vista?
    By austin.mn in forum Community Club House
    Last Post: 03-11-2007, 03:23 PM
  5. Is it possible to turn closed round bushing into C shaped bushing ?
    By vroemm in forum Linear and Rotary Motion
    Last Post: 06-27-2006, 11:04 PM
