586,544 active members*
2,576 visitors online*
Results 1 to 6 of 6
    Jan 2011
    Unhappy Sodick BF275 problem in axises
    Please Help
    the axise of my wirecut do not move during wire breakage!
    What should I do? If the wire breakes threading is not possible!
    Email:[email protected]
    May 2010
    Quote Originally Posted by ehsan.amouzegar View Post
    Please Help
    Are you talking about return to thread point. There is a parameter setting for what to do if wire breaks. It can be turned off if a return to zero will hit a clamp or something.
    John
    Dec 2006
    131
    Make sure you program either has a T91 or a G29 (G29 is thread return position and T91 is the thread code). Also make sure the "AWT REFERENCE" is set to 01 in the settings parameter.
    Jan 2011
    Unhappy Bf 275 Help
    Is there Any parameter in sodick machines that bring back the settings and all parameters to default mode?\
    [email protected]
    Jan 2011
    Angry Sodick Bf 275-Need Help In Disks!HELP
    My floppy disks burnt out and I use the system and users of A500 machine so the AWT settings are active and I have problem with this Like:In wire Breakage,the X and Y axises do not move and If the workpices was too height threading is not possible!
    Can any body send the system and user disks of BF 275 to me?
    Dec 2006
    131
    there is no default parameters button on that machine. you will have to use the paperback printout of that machine if it was given to you when the machine was sold. If you use other machine parameters your gain and other settings for each axis will be different.
  1. Fanuc OM alarm 310-320.. Axises need ZRN
    By m_ghaff2000 in forum Fanuc
    Last Post: 06-09-2023, 11:38 PM
  2. Sodick EDM machine Model A7C with MARK XI Control - Start up problem
    By rajappa in forum EDM Discussion General Topics
    Last Post: 02-04-2021, 08:57 PM
  3. Sodick A-280L problem
    By mikemck in forum Waterjet General Topics
    Last Post: 07-07-2014, 11:41 PM
  4. sodick bw 275 re-boot & locked keyboard problem
    By john.f in forum EDM Discussion General Topics
    Last Post: 10-16-2010, 06:08 PM
  5. Methods and apparatus for pre-planarizing cnc axises
    By eloid in forum CNC Wood Router Project Log
    Last Post: 02-27-2007, 04:35 AM
