586,106 active members*
3,165 visitors online*
IndustryArena Forum > MetalWorking Machines > Kitamura > Kitamura Mycenter 2 Tool Change Macro Program
Results 1 to 6 of 6
    Aug 2010
    24
    Hi
    Can anyone help me with the tool change macro program for our Kitamura Mycenter2 with Fanuc 6M control. We have lost the sub program for tool change after initalising the memory. We had a system error 908 alarm and we initalised the memory. Now we have lost all the programs and sub programs in the memory. When machine is asked to do a tool change it gives the alarm 078 program error. Has anyone got a sub program for tool change. Your help will be much appreciated.
    Jun 2003
    70
    Did you get an answer?
    Jim
    Jim Short
    www.tahlinc.com
    Aug 2010
    24
    Quote Originally Posted by tahlinc View Post
    Jim
    Hi Jim
    Yes Please try the following macro program for tool change.
    O9000;
    G80M9;
    G91G28Z0;
    M06T#149;
    G49;
    M99;
    Please inform me if it works for you.
    Jun 2003
    70
    Thanks!
    How are you calling 9000 and setting #149 global variable?
    Jim Short
    www.tahlinc.com
    Aug 2010
    24
    Hi
    In the program I write tool number and when it reads "T" command, it calls the macro automatically. e.g my prog will look like the following.
    G54G90;
    G28Z0;
    G28X0Y0;
    T3;
    S500M3;
    etc., etc,
    So when machine reads T command it calls the macro (O9000)
    But to write macro for tool change, you need to enable parameter switch so that it allows you to write and make sure you disable the switch after writing macro. I hope it will work for you too.
    Good Luck
    Jun 2003
    70
    This worked!
    (call with M66 P320 = 66)
    :9001(TOOL FETCH)
    #1=#4120
    #2=#4003
    G00
    G40G49
    G80G17
    G91G28Z0.0
    G28X0.0Y0.0
    S100
    T#1
    M6
    Y-33.
    Z-5.
    G#2
    M99
    Jim Short
    www.tahlinc.com
  1. help in macro program for tool change
    By traxxtito in forum Parametric Programing
    Last Post: 11-26-2009, 11:17 AM
  2. macro program for tool change
    By traxxtito in forum DNC Problems and Solutions
    Last Post: 11-10-2009, 02:32 PM
  3. Macro program tool change O9000
    By baow in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-13-2009, 10:58 AM
  4. Replies: 5
    Last Post: 08-09-2007, 09:25 PM
  5. Replies: 2
    Last Post: 05-25-2006, 05:15 AM
