586,115 active members*
3,469 visitors online*
Results 1 to 6 of 6
    Mar 2007
    13
    AXYZ Millenium Question
    Does anyone know how to install the LRC card for a 2000 AXYZ Millenium? I just bought one and want to make sure I do this right. I just finished building a tower to run the old AXYZ toolpath software (has to run on Windows 95 or 98). I can't get any help from AXYZ because they don't support this setup any lomger and can't quite affore the 6000.00 upgrade to their new controller.
    Any help would be appreciated.
    Thanks, Don
    Apr 2011
    12
    It is simple plug in and go. Make sure you have the jumpers set for PORT 3. Simply plug it in and make sure that in ToolPath you have selected LRC-3. No drivers needed.
    FTP
    Mar 2007
    13
    Quote Originally Posted by ftptorrent View Post
    FTP
    Thanks! The only slot in my motherboard that it fits in is a bit longer than the card itself. All the pins line up but i'm not sure if it's the right slot. I don't know if the PC is recognizing the card or not. Haven't plugged the machine into the card yet for fear of frying it.
    Apr 2011
    12
    It should be a black ASI slot. Are you sure it is not 2 slots side by side? As long as the slot is black you should be ok.
    Mar 2007
    13
    Yep, It's a long black one. Looks like it's divided into two sections, one after the other but the AXYZ card only fills the first. Is it safe to plug the machine in and go for it?
    Apr 2011
    12
    Yes plug it in and turn on the computer should be good to go.
  1. AXYZ / Toolpath question
    By revwarguy in forum Commercial CNC Wood Routers
    Last Post: 09-11-2013, 10:15 PM
  2. Which CNC AXYZ or Tekcel
    By Rich458 in forum Want To Buy...Need help!
    Last Post: 10-12-2010, 10:06 PM
  3. axyz posting help
    By cnc metalcraft in forum Post Processors for MC
    Last Post: 09-19-2008, 05:06 AM
  4. bobcad on a axyz
    By cnc metalcraft in forum BobCad-Cam
    Last Post: 01-29-2008, 08:03 PM
  5. tool changing with AXYZ Millenium
    By frankbergeron in forum G-Code Programing
    Last Post: 07-17-2007, 01:33 PM
