Based on experience, what is the typical speed difference of similar torque (lets say, 100 oz.in) steppers compared to servos?
And, what are the optimal reduction rates or servos, for steppers?
Rgrds,
Indrek
Rgrds,
Indrek
Servo have their rated torque over their RPM range. Steppers's torque goes from max at low RPM to minimum at highter RPMs.
100 oz is 100oz. But, like Viper says, steppers will have less torque as rpm's increase, where as a servos torque is constant. Steppers are usually best driven directly, unless VERY slow speeds are required. The optimum reduction ratio for a servo would depend on the machine. Load it has to move, speed required...and other factors, all come into play.
100 oz.in. is torque, not speed?
Ok, if the only/most effective way to use steppers is 1:1 reduction (and in any case no more than 2:1, but can it be useful in other way end, i.e. like 1:2 ?), and as in the same time servos are having constant torque over rmp range, but they have (can have) generally n times higher RPM (but using m times reduction changes the actual outcome), then we can state, that similar torque rated servo is having n/m times faster actual speed but has m times more torque? What are typical rates for m and n ?
Or other way end:
if preferable stepper is 600 oz.in, what kind of servo (oz.in.) and reduction I should use to have similar end speed? Typically, as probably every single stepper and servo motor has own exact specs? But are there some kind of "general rules"?
Or:
of course every mechanical setup has on need for torque and speed. but in servo case I can use not only bigger motor, but also play with reduction to select suitable motor. How I will decide, when to stop adding RMP and select bigger torque servo? Or why not use 1:1 reduction with servos too?
IMO,
There is no comparison. Servo's are the only way to go. More expensive at the beginning, yes, but cheaper in the long run as you will not loose steps and destroy a job. Steppers are a thing of the past. Servos are cheap enough now to consider.
"A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
Greetings From Down Under
Dave Drain
Akela Australia Pty. Ltd.
Its funny how they are bringing out steppers these days that they then put encoders on them, and call them Smart steppers / hybrid steppers etc. Essentially they are working the same as servos. Why would you bother with the effort when you can just use straight servos anyway.There is no comparison. Servo's are the only way to go. More expensive at the beginning, yes, but cheaper in the long run as you will not loose steps and destroy a job. Steppers are a thing of the past. Servos are cheap enough now to consider
I can testify first hand how my servos saved a cutting job I did when the spindle got bogged. When the spindle raised, the machine jumped back to where it should have been and continued to cut the job. I just wound down the feed rate and the rest of the cuts were fine.
Kooka, I am still waiting very patiently for your new servo drives to be released
Whats the hold up?
Benny, can't you also testify how the following error on your servos was giving you that problem?
A properly set up stepper system will never lose steps. An improperly setup servo system won't run very well. There is nothing wrong with steppers. Mariss from Gecko says that up to ~150W (I think, can't remeber the exact #), steppers are a better choice. If you need more power, than servos become a better choice. Steppers are cheaper, easier to setup, and don't need the added gear reduction, which costs more and adds more complexity.
Hmm, I am not sure what you mean Jerry. When I was doing the cutting it was into 1 inch poly something. As this stuff heated up it actually bacame hard and wrapped around the top of the spindle stopping the machine from moving along the material.
To say that "A properly set up stepper system will never lose steps" is not like you. We have both heard of many instances where this has happened. Servos will correct the loss though, if they are freed., steppers will not.
I dont see how that could be called impropperly set up?
Is this what you mean?
A properly made setup for steppers or for servos - what this actually means IRL? Just about selecting right sized motor and reduction rate pluss ensuring that everything runs smoothly plus measuring correctly existing backlash, or what?
Or, what in addition you must take care speaking about servo setup?
Rrds,
Indrek
To somewhat compare a stepper to a servo, compare the stepper rating, say 250 oz-in, which is holding torque, to servo max torque divided by about 2. Use the belt/gearing reduction when you make the calculation.
Here are the numbers for our Globe servo motors:
20 oz in continuous, 178 max, 2800 rpm
2.8:1 belt reducer yields 60 oz-in continuous and approx 500 oz-in max, at 1000 rpm.
1000 rpm happens to be a sweet spot for desktop machines like the Sherline, Taig, the mini and micro imports, which use 20 threads per inch screws. It is also just about perfect for a 10 tpi acme screw which is a good size to use on a benchtop CNC router. 50 ipm on the mills and 100 ipm on the routers is about as fast as you can go when using brass or delrin antibacklash nuts on these machines.
If you have ball screws and rolling slides ( linear ball guides/roller bearing wheels ), which both have reduced friction, a 5 tpi thread is very common and that multiplies the above speeds by about 4, all from the same 1000 rpm servo motors w/reducers.
some additional comments:
1) These motors are often driven by our 150 watt servo drivers and provide a stiff and accurate positioning system, well within the desired tolerances for all the machines I mentioned, and at about 1/2 the price of other servo drivers.
2) Steppers usually have so little torque at 1000 rpm that they can barely move the machine table or gantry. The result is that a stepper makes a nice slow machine with little high speed cutting capability.
3) Servos have additional dynamic capability that does not show in the above calculations. At any time a need for sudden acceleration or additional cutting power in any axis can temporarily draw on the surge capability in a linear power supply. This does not cause a loss of position on the machine
Fred Smith - IMService
http://www.cadcamcadcam.com
I can't find the thread with the problem you were having. Maybe I was mistaken, but I thought your servo's were lagging a bit behind due to the following error, resulting in an incorrect cut path in 1 spot of your program. Or was it a different problem?Originally Posted by ynneb
A properly "designed and setup" stepper system should not lose any steps. If steppers miss steps, it's because either the stepper is too small for the application, or the machine is binding somewhere (incorrectly setup). Most of the people you mention that are losing steps are using small (~100 oz) motors, and are trying to go faster than they are capable. Try to use too small of servos, and the drives will fault, which may still ruin your parts.
There is nothing wrong with steppers, if they are sized properly for the application. You should be able to run a stepper machine all day long and never lose steps. If you do, either the steppers are too small for the machine, or there is another problem. Steppers are NOT the problem.
Originally Posted by imserv
If you use high lead screws (2-4tpi), you don't need to spin a stepper at 1000RPM. You can spin it from 200-500rpm and still get the 100ipm you're talking about. And by spinning it slower, it has more available torque.
You can design a machine for steppers, or design it for servos. The drive machanicals will be different, but you can achieve the same results.
To imserv: thnx, very useful answer!
So, accordingly to your nstructions, this is then equal to 250 on.in. stepper...Originally Posted by imserv
I am not sure, are they suitable for me needs? Some of the people are suggestng 500 to 600 sq.in. direct drive steppers for SIEG X3 sized mill...
Rgrds,
Indrek
Basicaly equivalent holding torque to 250-300 oz-in stepper. However a servo produces much more dynamic performance at all speeds.
This size servo is useful up to about a 1 hp spindle. Above that rating you will expect to exert more force on your cutting tools.
The Seig X-3 is a small frame mill with a spindle the size of a bridgeport( 2 or 3 hp). If you want to take advantage of the spindle power, size your axis drive motors accordingly.
You are looking for a servo motor that will produce about double the power of the motors that I described.
Check out the motors on this page:
http://www.homecnc.info/plans.htm
http://www.cadcamcadcam.com/hobby
Ah yeh, I think I know the thread you were talking about.
http://www.routec.com.au/index.php?topic=37.0
Actually here is a good example of a bad cut that was not the fault of the servos, but demonstrates well how the remainder of the cut isnt wrecked. It was just a matter of redoing the cut and all was fine. If a person had this problem with steppers it would have offset the rest of the cut and there would have been no way you could have fixed up the job.
In the end the only reason this happened was because the router tip was blunt and instead of cutting the material, it rode the cut, sort of like surfing a wave.
If this doent demonstrate superiority of servos then I dont know what will
No one is saying there is. However the topic of this thread is "servo vs stepper" and we are talking about the differences.There is nothing wrong with steppers, if they are sized properly for the application
Read post #5Originally Posted by ynneb
He he, the old stepper vs servo thing, always reminds me of the old Ford Vs Chev debate. You will quite easily determine who owns what by the way they defend it.
Well servos are the way to go....steppers are an inexpensive way to go....either way you go.....
IMServ: how do you calculate/find out those HP-s? Stupid question, but does it stands for horsepower of spindle motor?
Original Sieg X3 is rated 600W --> should be around 0.8 HP
Super sieg X3 is rated 1000W --> should be around 1.34 HP
Then it seems, I dont need so big motors at all?
Other specs for super X3 are available at http://www.siegind.com/Products/br-x3-super-lathe.htm
Btw, should I use W to HP conversion international, metric or electric conversion rate? Probably electric
Rgrds,
Indrek
