586,106 active members*
2,987 visitors online*
    Dec 2006
    947
    Heat proof templates for plasma cutter
    I'm looking for any material that's around 1/8" thick or so that's FLEXIBLE to make some plasma templates out of.
    I need to cut some parts free hand on a round tube and want to make some templates that can bend easily and not burn up.
    Any help is appreciated, thanks.
    Dec 2006
    86
    Bendy Stuff
    Check out Target in the kitchen section, all that new silicone bakewear stuff might be the trick.
    Jan 2008
    2247
    I have used everything from carboard to PVC pipe (slides over the tube to be cut) as templates. If you use a shielded plasma torch (Hypertherm) there will be very little heat imparted on the templet. Move the template immediately after cutting so that heat from the metal that was just cut does not damage or melt it.
    Jim Colt
  1. CNC Laser cutter versus CNC Plasma cutter?
    By squale in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-24-2020, 02:14 AM
  2. My new Plasma Cutter
    By Grobschmied in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 02-14-2009, 07:02 PM
  3. What Plasma Cutter To Buy?
    By CPierce18 in forum Waterjet General Topics
    Last Post: 02-06-2008, 12:13 PM
  4. Cutting heat proof material. Is it safe?
    By Robin Hewitt in forum MetalWork Discussion
    Last Post: 10-25-2007, 07:47 PM
  5. Plasma Cutter
    By studysession in forum Waterjet General Topics
    Last Post: 09-03-2007, 03:23 PM
