Hey there, I have an AXYZ 6010 router which is probable about 15 years old. The problem I'm always having with this machine is that at some point, without warning, the router will simply stop dead in it's tracks while I'm running a file. Each time this happens I open up the electrical box located in the back of the table and pull out the 20amp fuse to find that once again, it has blown. I replace the 20amp fuse, start the machine up again (and try to find home again which is lost as a result of the blown fuse), but sure enough some time down the road the fuse blows again. Does anyone have this same problem or know how to fix it for good so that I can run the router with some peace of mind?
Forbes
