586,114 active members*
3,371 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Fixture offsets, X3
    Fixture offsets, X3
    Just received a batch of programs from my contract programmer. He is a good machinist but may have tweaked something he doesn't know about. What setting changed? I used to get just the fixture offset at the beginning of the program to having one at every tool change? In the past I'd only edit it in one place, he would run the programs, I'd edit where I wanted it to run and then sent it.
    My programmer almost scrapped a bunch of parts in a sequential machining package. Tools changed and it jumped back to the first part. He's now posting a E1 at every tool change and I've got to track through the program and replace it every instance.
    Any thoughts?
    Dec 2008
    3109
    If you are both using the same post
    it may be the Misc Integer #1 being set different
    or a "Lock on to 1st WCS" setting not being set the same
    also compare the Work Offset # that is set in the "View Manager", you may set each each view, where he has only set the offset on the main WCS view
    Thanks Super,
    He needs to set them to 0 or -1 default to have them post E1. I don't know why it puts one at every tool change but I know it does so if I need to edit the .nc file I know now.
  1. Mazatrol/EIA fixture offsets
    By gneal in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-17-2010, 09:09 AM
  2. Z Fixture offsets
    By gbpacker in forum Fadal
    Last Post: 09-02-2009, 09:41 PM
  3. fixture offsets
    By beartrax in forum G-Code Programing
    Last Post: 11-15-2008, 01:19 AM
  4. FIXTURE OFFSETS
    By BAD DOG in forum G-Code Programing
    Last Post: 05-02-2008, 12:23 AM
  5. Multiple Fixture Offsets
    By Benji in forum EdgeCam
    Last Post: 05-02-2007, 10:28 PM
