I'm restoring an Ex-Cell-O 605 CNC milling center to operating condition and after removing the cover to the Z-axis ballscrew, I noticed a thin black plastic oil tube that had broken into several little pieces laying on the bottom bracket around the axis bearing.
The copper oil plumbing comes into the head to a fixed compression fitting that sits on the left side of the ballscrew about midway along the Z axis. A plastic tube then connects via a compression fitting to this main oil feed and runs down for a few inches then curves back up and attaches to another fitting on the ball-screw nut.
I have no idea why the tube broke, and am quite puzzled by why it broke into so many pieces. Some of the pieces appear to have been severely crushed by the Z-axis mechanism. My guess is that it was too cold in my shop while I tested the Z-axis causing it to break. Alternatively, it was a prexisting condition (which may spell trouble for me in the future. The ball screw was nice, shiny, and lubricated, so I'm hoping for the best, but the bottom bearing however is missing 1/4 of the seal. Yikes.)
At any rate, I have these little bits of unidentifiable black tubing (see photos) with the approximate dimensions: 0.095" OD x 0.05" ID. It's difficult for me to measure the tube dimensions exactly, but it doesn't appear to be a 1/16 ID tubing. I'm hoping I'm wrong.
The tubing is also quite rigid given that it's supposed to flex with the z-axis. I'm surprised, really, considering that it makes a full 180 degree turn inside the head with a radius of roughly 1.25". I would have expected a more flexible material.
Is anyone familiar with this type of tubing? Anyone know what kind of material this might be? If I can identify the material, I can probably find a supplier. If however you know that too, I'd appreciate it.
When I replace the tubing, I'm going to cut a slightly longer piece and coil it around one full time before connecting it back to the fitting. Hopefully that will prevent it from cracking in the future.
I'd also be interested in your opinion regarding suitable tube material types. Fluropolymer tubing seems like a good choice.
Torin...
