586,112 active members*
3,081 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > fixed gantry router built in solidworks
Results 1 to 8 of 8
    Mar 2010
    Hello
    I've finished designing my first cnc router and would appreciate any comments or tips before I get any farther in the design, as I'm sure there's a lot of room for improvement. The machine itself is 80/20, mostly 1530 with 1545 on the Y axis. I've listed my own concerns below.
    Concern 1: The X axis has one long carriage per side from cncrouterparts. Should I consider adding a second set to the inside of the rail?
    Concern 2: The table is 44.25''X13''X.5'' 6061 T6 aluminum. Should there be an 80/20 support frame as well?
    Paul
    Attached Thumbnails Attached Thumbnails mill front.jpg   mill side.jpg   mill top.jpg   mill front iso.jpg
    Feb 2011
    I think a single carriage should do fine.
    You might want to consider moving the gantry forward and mounting the y axis on top of the supports toward the back. Right now, there is a lot of weight toward the front of the gantry, which is bad for your bearings and such.
    Nov 2006
    1036
    I think your machine is prone to racking along the gantry axis. I would suggest that you beef up the supports behind your gantry. I just built a small fixed axis router and commited a large portion of my 8020 material to the gantry. (and used 1/2" and 3/8" aluminum reinforcing plates
    Nov 2006
    1036
    Here's another shot of the back showing a 3/8" aluminum reinforceing plate on the bottom of the back of the router.
    Nov 2006
    1036
    I would also consider using dual (slaved) steppers to drive your bottom table because the table as you have it drawn is likely to twist around the Z axis as you cut at the far left and right sides of the table.
    Aug 2008
    1166
    Yes, I would support your table. It depends on what you're going to cut, but unless you only plan to do foam or something similarly easy to cut, I would support it more.
    CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
    May 2004
    162
    Question Torsional weight
    Quote Originally Posted by Reed92 View Post
    I agree whole heartedly. I have a rail on both the top and on the front for this very same reason. My X axis is over 60" of 3030. Thanks. Mike
    Mar 2010
    The comments have been extremely helpful, sorry for the long delay between posts. I didn't realize that building a fixed gantry machine with a cutting area 44'' long would be quite so difficult, which is why all the comments are so appreciated.
    Thanks for the suggestions donframbach, I never thought about the table racking due to cutting on the ends. I'm going to redesign and make the machine a moving gantry, for which I'll post pictures under the same thread (though I will rename the thread).
    Paul
  1. New DYI Fixed Gantry Router Build
    By DonFrambach in forum DIY CNC Router Table Machines
    Last Post: 07-06-2015, 12:45 PM
  2. Fixed gantry router
    By KTP in forum DIY CNC Router Table Machines
    Last Post: 04-17-2011, 11:44 PM
  3. Fixed Gantry Router Bearing Position Q?
    By Gliderask21 in forum DIY CNC Router Table Machines
    Last Post: 11-26-2010, 11:37 PM
  4. fixed gantry
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 01-29-2009, 11:20 PM
  5. Fixed Gantry
    By Auzze in forum DIY CNC Router Table Machines
    Last Post: 07-25-2004, 08:34 AM
