586,100 active members*
2,646 visitors online*
    Mar 2008
    7
    Mazatrol sub program in EIA
    Im trying to run a probe z touch mazatrol sub program from an EIA Pgm. I just need to know if there is a way of running the mazatrol sub without an X and Y location? Its on a Nexus 510c 640 fusion control. No inspection plus or id use that.
    Thanks any help would be greatly appreciated
    Sent from my DROID2 using Tapatalk
    Sep 2008
    51
    You can run the Mazatrol probe program as the main program, then run the EIA program as the sub-program. This works for me. If you use the WPC in Mazatrol, you can remove any fixture offsets (G54-G59,G92,ect.) from the EIA program.The EIA program will follow the WPC from Mazatrol program. This would be on an M32 control.
    Good Luck!
  1. I could REALLY use a sample EIA-ISO program for my Mazatrol Cam T-2!
    By revlimit in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-02-2014, 05:40 AM
  2. Mazatrol Program into a G Code Program
    By fuzzman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-25-2012, 04:27 PM
  3. Mazatrol Sub Program
    By jhersh in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-03-2008, 11:09 AM
  4. Restarting in mazatrol program
    By Castle1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-04-2007, 12:43 AM
  5. Need IEI-ISO sample program for Mazatrol 640 T
    By turkaygeyik in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-29-2007, 03:03 PM
