586,500 active members*
2,703 visitors online*
IndustryArena Forum > CAM Software > Mastercam > there is no disk in the drive. Please insert a disk into drive\device\harddisk\dr2
Results 1 to 8 of 8
    Sep 2010
    135
    since we installed the new windows 7 we always get the message saying
    any inputs on how to fix this conflict?
    I tried to install mastercam all over but the message keep coming up.
    thank you.
    Sep 2010
    135
    Quote Originally Posted by PRINT_FX View Post
    thank you.
    forgot to mentioned that we get this error message when opening or saving a .mcx file
    Mar 2007
    95
    Did you recently save/read from any removable disk in MC?
    Check Seeting-->Configuration-->Files to see if any entry points to removable drive that's no longer there.
    Dec 2008
    3110
    You may find that you have a path in the operation manager that is targeting a removable drive
    ie post to location in the "Files" tab (Toolpath Directory is common)
    or perhaps calling in a stock file
    Sep 2010
    135
    everything looks good, all the paths are to the right dir etc...
    but I did use a USB HD to move the post and other files around. very strange never happened before...
    if I click files tab/operation manager and then ok, the message comes up right way as-well...
    also if I do save as I get the message too..
    Aug 2009
    986
    I've had a problem with Mastercam 5 under XP. Whenever I launch it, it goes back to my In Development folder and recreates subfolders that I have deleted.
    I suspect that you're having a similar issue with it trying to recreate folders on a drive that is no longer there. Try putting a blank USB drive in and see if it recreates old folders on that drive. If so, then you and I are having the same issue.
    I don't have a fix, sadly. I shut down Mastercam, went through the registry and removed all references to the folders, then rebooted. It didn't fix the problem, so the folders are referenced somewhere else.
    Frederic
    Sep 2010
    135
    well I decided to download and install the X5 version and look good now, so far.
    is there a verisurf for X5?
    Jan 2012
    "there is no disk in the drive. Please insert a disk into drive\device\harddisk\dr2"
    this error will comeing when i connect to the my labtop to net connection (tata photon plus) please give me the idea to remove this problum.
  1. Hurco disk drive
    By MadPickinSkills in forum HURCO
    Last Post: 09-12-2010, 07:10 PM
  2. Burny 2.5 Plus Floppy Disk Drive Needed
    By themachineman in forum Waterjet General Topics
    Last Post: 12-28-2009, 04:31 PM
  3. Floppy Disk Drive USB Reader Upgrade
    By PLRElectronics in forum News Announcements
    Last Post: 01-28-2009, 08:25 PM
  4. T-2 Control Upload / Download, Disk drive, or Bubble memory ?
    By Andrew M. in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-30-2007, 07:05 AM
  5. M32 System Disk
    By bean79au in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-08-2007, 01:25 PM
