586,096 active members*
3,378 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > milltronics centurion 5 fault
    Apr 2010
    I have been helping a friend with a milltronics centurion 5. My machine control experience is low, but I have a background in electronics. I have repaired a few welders at component level, so I thought that I would try to help out.
    He had received a repaired servo board, and as soon as he installed it the cap on the board near the bridge rectifier exploded. Turns out the 10uF 150V cap had been installed backwards. It removed a small amount of the board trace as well.
    I replaced the cap, repaired the component side of the trace, the board was re-installed, and no happiness.
    The Milltronics Centurion 5 reads out positions, but the machine will not home.
    The display will indicate drivers on, and as soon as you tell it to home, the display shows "homing x axis and homing y axis" then 400 error and the drivers toggle to off.
    Is this indicative of a driver board problem?
    The limit switches both operate, if you travel past them the display indicates that they had over traveled.
    Where should I look next?
    Paul Sperbeck
    Apr 2010
    45
    you have dc drives on that machine you can interchange the two drive boards just the connections and that will help you to isolate the bad board or motor you also have fault lights on those boards. good luck
  1. milltronics partnerIV centurion V
    By bullitt92 in forum Milltronics
    Last Post: 07-06-2010, 10:51 PM
  2. Milltronics 3 axis Centurion 6
    By Chizel in forum GibbsCAM
    Last Post: 05-04-2010, 05:25 PM
  3. Milltronics Centurion 4 amp capacitor
    By ozturbo in forum Milltronics
    Last Post: 10-30-2008, 07:06 PM
  4. Milltronics Centurion Six
    By CUTRITE in forum Milltronics
    Last Post: 10-13-2006, 07:48 PM
