587,033 active members*
3,730 visitors online*
    Jan 2011
    Dual Motor Axis?
    Hi, im wondering if this idea is fesible, or, if it has already been accomplished how did it go?
    Got belt driven axis, x and y. Failry long (500mm by 1000mm). Got Nema 17 motors (0.6amp) with a cnc controller which can control upto 3.5amp. Got t5 pulley’s with 16mm wide belt. Now then, it is possible if i use two motors wired in as one for one axis? i mean, put one motor at one end and one motor at the other end connected by a belt. would resistance in the wires have to be the same in order to get each coil inside each motor the same amount of power?
    I am trying to increase accuracy, torque and overall cost as i have a few nema 17’s, i am aware that it would be easier to get a higher motor to achieve all this but i would like to mix it up a little. Has anybody tried using this set-up with a belt driven table?
    Duncan
    Jan 2011
    woohoo it works
  1. Dual Steppers or Timing Belt for Dual X-axis?
    By GEBrown in forum Linear and Rotary Motion
    Last Post: 05-27-2010, 05:45 PM
  2. Dual Z axis and Dual Spindle
    By Adamj12b in forum Mach Software (ArtSoft software)
    Last Post: 08-28-2008, 09:15 PM
  3. Replies: 3
    Last Post: 07-04-2008, 12:57 AM
