586,913 active members*
2,916 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > spindle assembly/parts drawing for a SV-50?
    Feb 2011
    640
    anyone have one? need to pull the spindle, would be handy to know what lies inside
    Feb 2009
    6028
    SV50 spindles are my lease favorite to do. I don't have prints i can send. I do remember having to change the upper bearing when doing a spindle, so all the motor leads had to be disconnected to get the upper housing out. First one I did took me almost 2 days, but then it was 115deg in the shop those two days. Don't forget the small set screws in the side of the sensor ring. If you try to get it off without loosening them, your hosed. You will need a 29mm socket to remove the coolant coupling. Don't try to work around it, the ceramic chips easy and it 2 grand for a new one.
    Feb 2011
    640
    thanks for the insight...I havent even looked at the thing yet other than give it a spin, feels like gears clashing...but pretty certain theres no gearbox on a motorized spindle...
    quick question- are the bearings straight bore angular contact or taper bore cylindricals? just wondering if its gonna be expensive or real expensive
    Tim
    Feb 2009
    6028
    It going to be expensive, you CAN NOT CHANGE BEARINGS YOURSELF. This has an armature on the spindle shaft with hydraulic nuts. Only re-builders with the correct equipment can do these. If you try to do it yourself, you will be buying a brand new spindle from Mori. Figure 5K minimum for rebuild. Then you will need the upper bearing, about 600.00 additional. The upper bearing sits in a floating housing, with ball bearings to allow it to float. This is not a simple job on a SV. The newer machines are pretty easy.
  1. Arrow 500 need drawing for drawbar assembly
    By scudzuki in forum Cincinnati CNC
    Last Post: 08-22-2016, 08:51 PM
  2. Spindle Assembly Drawing for Mori VMC SV500/40
    By shivisood_24 in forum Mori Seiki Mills
    Last Post: 12-18-2010, 01:56 AM
  3. Boss R2E3 - need drawing of head assembly
    By Scott Kelley in forum Bridgeport / Hardinge Mills
    Last Post: 09-08-2008, 09:31 PM
  4. Creating cavity from assembly parts?
    By Rich05 in forum Solidworks
    Last Post: 07-24-2008, 01:01 AM
  5. Trimming parts in assembly
    By Capgama in forum Solidworks
    Last Post: 09-19-2006, 03:49 PM
